hey guys,
i had been experiencing higher then expected temps in my 32 GTR (although that was reading stock temp guage so how accurate that is... is anyone guess!) it was frustrating as the clutch fan was pretty well alway atleast 30% on even in <12c weather. and i hated the sound of it blowing all that air and the feel of the drain on the engine.
So, i decided i would first of all flush the coolant and see if that did anything, if not i would replace the thermostat, if that didnt work i was gonna get serious and buy a Koyo triple pass full alluminium rad (see the steps increasing in price exponentially!)
Anyway i got under the car, opened the radiator cap, coolant recovery bottle undid the air draig plug and then emptied the coolant.. the crap that came out was like murky brown... yuk, anyhow, i rinsed water through it, this is where the GTR service manual didnt really work for me.
i tightened the drain plug at the bottom and filled (expecting it to fill untill coolant would escape the air drain plug (as per GTR Service manual: Pg. EN-249/250) where i would then fill to full no dramas. HOWEVER, the radiator just filled. period. nothing out of the air drain plug (i had turned the car power on to put the heater on too, as directed) anyhow, im like, 4L in... its not full.... FML, so started her up, let her run, turned her off and filled some more, (like 100ml) so i scrolled through the forums and figured fk it, opened the radiator and started her up.. and then just poored in with it running and the coolant flowing, this proved very effective as there must have been BULK air in the cooling system becasue it was just bubbling like.. something that needs to bubble alot! and not boiling, as it was only 50-65c to the touch (probably not smart?) anyway i was able to get about 5.5L into her in the end.
TL:DR - my question is: when refilling the radiator, is there any harm in filling her till the radiator says no (just ignore the air drain plug) and then start her up cold, wait for the thermostat to open and start flowing coolant and then just poor and monitor untill all the tiny little bubbles escape and the system is completely full?
Cheers
Dan
Ohh and looks like the coolant was the problem, cause took it for a 20 min cruise, and clutch fan wasnt really coming on at all!! :)
Yes. That is the way to do it.
If you really want to flush the system you need to get it hot so that the thermostat is already open. Then you remove one hose from the heater connection at the firewall and jame the garden hose in there and run fresh water into it while the engine is running. There is also a block drain on the passenger's side. This is a necessary step to get it all swished out inside when the system is really gunky. Not so necessary for a simple coolant change.
The "coolant" wasn't your problem. Coolant is mostly water regardless of how dirty it is, so it still cools. It just doesn't protect against corrosion and so on when it's gone old, brown and acidic. You must have had a partial blockage in the radiator that you freed by cleaning it out, or you might have had a poorly bled system (and assuming it is now properly bled) and it is now wet in areas inside that weren't properly wetted before.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
