Hi Guys,
Just letting everyone know my Skyline was attempted stolen at Westfield North Lakes carpark today around 1pm. Witnesses have come forward and forensics are coming for prints (there are nice ones on the window where they got in)
Now to find a whole new ignition barrel and basically a whole steering assembly as they snapped all plastic and controls.
Hope they get whats coming to them!!!
Also a shout out to William from North Lakes & Districts Towing private tow operator, this guy is a champion call out in 10 minutes and flat rate $88/hr, I recommend this guy for anyone who needs a tow Northside Brisbane.
Here are his details: http://www.truelocal.com.au/business/north-lakes-and-districts-towing/north-lakes
https://www.sau.com.au/forums/topic/427795-attempted-skyline-theft/
Yes alarm system and immobiliser system, saved it cos they couldn't start it, funny thing is they didnt steal the $1000 sound system, GPS, dash cam, prestige personalised plates or any tools that were in the car
Since you are near me pop past. I can sort the column and rekeying the car will be easy as well. Done plenty.
May pay to see if I can steal it as well.
^this right here, if he can make it run/ steal it anyone who knows what they're doing can, lucky break though in the fact they a) didn't get to steal the car and b) didn't pinch anything. Really makes me rethink ownership of a fabulous car all because a few c**ts who obviously can't afford their own want to steal them.
if they tried a basic hot wire would it be possible for me to disable (with remote) the alarm/immobiliser and touch the wires together and it start? unless they have stuffed my immobiliser in the process as my car chirps and central locking is active still?
Edited by GTS R33
Ok I am going to do something I usually do not do..
To take one of these cars for a ride you need to get past the column lock. Hammer or a crowbar is fine for that.
Then you need to get power on . Screwdriver works there once you destroy the key lock you twist to switch and you have a car .
Now if someone has done the job properly the the alarm and paging unit has triggered and the owner is on the way out with a baseball bat. If not the then the alarm wiring gets ripped out and the siren smashed. Then the car is gone.
All of this takes about 3-4 minutes max to do..
Have your attention yet?
I highly recommend you swing past Chris. I attended one of his security nights and it is amazing how fast someone who knows what they are doing can have them started even with a 'professionally' installed alarm/immobiliser.
Depends how the job was done. If it was me, nope. No amount of button pressing would stop the car.
That's no good at all.
By any chance are you a staff member that parks basically in the same spot down the woollies end out the front????
Might be a random question, but whenever I come over to the shop to do groceries etc probably 3 times a week I too always park at that end and there is always the same white 33 in the same spot. Sad to think but if it is you maybe they have been thinking about it for a while.
I got rego make and model of the offenders vehicle, am I allowed to post it on here?
Forensics have come around today and got all the prints and will be running checks. Now I can explore it seems no wires have been cut/stripped, just the ignition barrel and plastics. Maybe the alarm spooked them or they had no real idea what they were doing??? There is so many wires behind steering column its not funny. Westfield is going over footage to get images of car and trace back to people inside. If they have entered the shopping centre they will be on camera.
Depends on what R33 you mean PHT34 - there are a few regulars, i park Woolies area always but not always same spot, prob was me you are thinking of as i havent seen the other regulars for months (maybe theirs have been stolen)
Excel bogans aye. Probably down from depression bay.
Zeke bring it past and I will give it a once over.,
Might swing past next Saturday morning again if that works for you.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
