This is not an official SAU sanctioned event.
Hey guys,
As has been discussed around the traps, were planning on having drinks just because. Would be nice to get a decent sized group of people out for a few too many bevvies on a Friday night.
Who: anyone who isn't a knob who would like to come out for a few drinks and meet a few other people
What: alcohol. Lots of it
When: Friday, 12 July 4pm
Where: Starting at Jade Buddha on the river in the city and then god knows!
See you guys there!
https://www.sau.com.au/forums/topic/427837-sau-drinks-1207/
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
