Hey everyone, im selling my 1991 S13 silvia... Here are the specs:
- Black with Sunroof
- SR20DET motor
- 16" Advan racing wheels
- KYB suspension - lowered, not sure how much though
- GTR front mount (black)
- Blitz blow off valve
- T28 from s14a
- Blitz electronic boost controller dual sbc 2 (the new model)
- 3 inch turbo back exhaust with trust muffler
- Malpassi fuel reg with gauge
- HKS mushroom filter
- 95,000 kms (always serviced at 5,000 intervals)
- JVC MP3 unit 40x4 watt, sony xplods in the rear tray - i may include the amp
- Short shift kit
- Rego till next april
- Excellent rubber on all 4 tyres
- Black Tints
- Brant immobiliser
- Black Widow Alarm
- Volanti Sports Steering wheel
Also have lying around:
- Stainless steel manifold
- S15 turbo excellent condition
- Sard 650 cc injectors
With the T25 the car made 165 on the dyno,
With the T28 its making the same on less boost (around 12 psi)... It wasnt tuned properly as it was only run on a dyno day... i just wanted peace of mind that everything was fine and not leaning out for the time being.
Im not selling any parts separately i.e. the turbo/manifold/injectors so please dont ask
Take the lot for $14,300 ono
Call me for any enquiries 0416 343 883
https://www.sau.com.au/forums/topic/42801-for-sale-black-s13-silvia-k/
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
