Cheers for the warm welcome guys!
Got a couple of pics so far:http://imageshack.us/photo/my-images/802/q68w.jpg/ http://imageshack.us/photo/my-images/198/ag6m.jpg/
fairly stock, except for a big front mount, bov, wheels, 3inch exhaust that is way to loud and hsd coilovers all round.
has been sitting in a blokes shed for awhile, used to run a 25/30 combo and even an old dirty 30 back in the day (25/30 combo made 600 odd hp) but previous owner sold engine package and put a lowish kilometre stock engine and box in it.
It'll be my daily driver so things will stay pretty sedate for awhile until i get up a good piggy bank to start playing.
https://www.sau.com.au/forums/topic/428479-hey/#findComment-6925119
Yea i know mate! Annoys me everytime i see it lol, all i need is the little part that flips though im pretty sure? Wonder how hard it'd be to find one, guess im in the right place to try.
not sure. I know wreckers may have them or on gumtree. but im pretty picky too so would annoy as me well :D
https://www.sau.com.au/forums/topic/428479-hey/#findComment-6925153
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
