Hi all, just letting you all know im in the process of making an airbox for my c34 as genuine nissan airbox is basically a mortgage and custom fabrication is harf to find. So far I just have a template made out of cardboard and will make it properly out of some plain black heat reaistant plastic.
When I go out and buy things I will put them up in here and let you know how I went about making the final product.
These photos are what im planning on making the final product look like so any thing you see wrong or needs improvement please let me know. All critisism welcome haha.
Cheers :)post-112770-13738833025429_thumb.jpgpost-112770-1373883287587_thumb.jpgpost-112770-1373883372235_thumb.jpg
https://www.sau.com.au/forums/topic/428717-c34-stagea-diy-airbox/
Alright so the airbox is done. Only took a couple of hours as you'd expect. And as usual the only things I used were
-heat gun
-$50 of plastic or acrylic from bunnings
-side cutters (clean cuts on warm plastic)
-right angle brackets from bunnings
-some nuts and bolts I already had in the garage.
Hooe you like my version of the d.i.y airbox
Yea I would've liked to have it clear but being a p-plater even just having it glossy the way it is will be enough for me to get in a little trouble so trying to keep it relatively low key, it also hides the intercooler pipes so it looks like it goes from the filter straight to the t/b. It's a very tight fit as well haha. Thanks :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
