HOWTO: RB25DET High Boost mode with standard solenoid
Till the new ecu saves your engine with its engine protection and then you realize it’s worth double what you paid for it
Not sure at all when you think I just spent 2 days looking for a pdm rather than just I stalling a relay
That's why I have the nismo brackets, and the offset on the jic arms is also different from stock (closer to Cusco version) But they are fixed length which sucks.
Yeah we run standard arms with superpro adjustable at each in the race car due to rule restrictions. They do flog out due to the geometry issue once you add caster, we just treat them as a regular maintenance item
I did, I have the jic -10mm arms which are 170mm fixed (no adjustment) I might shove whiteline bushings in them to get the adjustment if I can't find noltecs. Not totally sure they will fit though.
