hey everyone i've spent a decent amount of time looking around and deciding on a car. I was going for an r33 but i had the issue of size, being a larger guy so ive decided on an r34. Im only going to be on my p's so i need a non turbo and would love to know if anyone knows of places i can get one for around 6-9k which i know can be done from what i have seen but am really interested in a coupe model im from melbourne so if anyone knows anything please let me know where they are!
i am happy to import if need be provided it keeps with in my price range.
https://www.sau.com.au/forums/topic/428960-seeking-non-turbo-r34-coupe/
It's not worth going through the import process for a non-turbo r34. Anything short of a very good condition GT-R (there's plenty here too), you'd be better sourcing locally.
6-9k is going to be a BIG stretch though mate. From what I've seen, you're probably looking at 9-12k. 9k will almost certainly be an auto that's not going to be in top condition as well. I'd keep saving to be honest. Like with all skylines; any money you save by buying the cheapest car in the short term is going to cost you a lot more down the track.
Edit: Also, it's not a fine science.....finding these cars. The two best places to look will be here or on another classifieds website. We don't keep a secret list for those who ask.
http://www.carsales.com.au/all-cars/results.aspx?q=((((((((SiloType%3d%5bBrand+new+cars+in+stock%5d)%7c(SiloType%3d%5bDemo+and+near+new+cars%5d))%7c(SiloType%3d%5bDealer+used+cars%5d))%7c(SiloType%3d%5bDemo+and+near+new+cars%5d))%7c(SiloType%3d%5bPrivate+seller+cars%5d))%26(((Make%7b%3d%7d%5bNissan%5d)%7b%26%7d(Model%7b%3d%7d%5bSkyline%5d))%7b%26%7d(Badge%7b%3d%7d%5b25GT%5d)))%26(State%7b%3d%7d%5bVictoria%5d))%26(Service%3d%5bCarsales%5d))&sortby=TopDeal
Edited by Truffles
well going through what ive seen localy there are quite a few in the 12k mark i know that much but if you take the time to really go through it ive found a fair few that are sitting at the range im after, Again going thorugh that list drop down the trash boxes that the young teens think is the way to treat the car. but these sit around 156xxxks so idk ill check it out but thanks for the advice matey actually much apreciated.
I'd also almost ignore the odometer reading on all Skylines, they're never going to be legitimate kilometres on the car from new. They're a guide at best. The best use of an odometer reading is to get the best history on the car that you can. I own an R32 GT-R that was imported with (a probably false) 76,000km in 2009 and I bought it last year. It sits at 120,000km now and I had a full file of receipts and history from 76,000km when it came into the country until now. That's worth something.
Good luck with it all. Be patient, do your research and you'll find something you want.
Edited by Truffles
  • Like 1
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
