Gents,
I have searched but cant seem to find a pinout or wiring diagram for the Neo? I have got from Driftworks a fitting guide but nothing helping me with the wiring for my R34.
Now before all the haters jump on, im not doing this for flames and bangs bangs to scare old ladies. My Nistune is intermittently cutting the engine when it hits the limter, more so then less, so far cant find why, needs more time at the tuner, which isnt that easy. Hits the limiter, dies, needs to return to idle then has power again. Im wanting to use this to set it just before this happen's, turn the gain down and be able to know the engines not going to die. Then i can start saving for a VIPEC while i can still enjoy the car.
Thanks for the help, and please keep negative comments to FB.
https://www.sau.com.au/forums/topic/429048-er34-neo-pinouts-for-bee-r-limiter/
Thanks for the reply and link, very usefull.
This is what im thinking:
Red to Pin 31 Ignition power supply
Black to Pin 32 Control unit ground
Yellow to Pin 44 or 45 Crankshaft position sensor 120Ê (REF) signal
Green to Pin 46 Crankshaft position sensor 1Ê (POS) signal
White to Handbrake
