Over the weekend I have noticed an unusual sound from the rear passenger side wheel which i suspected might be the bearing. Over the last few days it has got worse.
So I took the wheel off and it turns out that it is the wheel bearing as there is a little bit of play when moving the top and bottom of wheel back and forward.
Just wondering how hard of a job is it to replace the bearing as I understand that it is held in by four bolts and it is not pressed in.
I do not have any fancy tools so if I was to attack the job, would I managed to get it off and replaced?
Thanks for any advice in advance.
https://www.sau.com.au/forums/topic/429549-r34-rear-wheel-bearing/
Taking the bearing out is easy but then you have to remove the bearing from the spline thats the hard part, youll need to make a few special tools to pull it off. Other problem you run in to is they seprate into 2 pieces when trying to press it off the spline and your left with half still on.
Putting tge new one onto the spline is easy enough if u have a press.
OK thank you for the advice.
This is the one which I have just ordered.
http://www.ebay.com.au/itm/360701961813?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
I thought that you have to just unscrew the bolts off the back of it! I did not think that you needed to press or unpress anything!
I think I might just get a mechanic to do the job as I don't have any specialist tools!
So looks like this is the wrong bearing. Got it to the garage and they told me that it was missing the top mount for the hand break. After looking around they managed to get one in however once it was all bolted on they realized that the shaft would not fit as it was 3mm to small!
I had no idea that the there different sizes!
Can anyone help me with this as I can not find the correct bearing for my car?
Hey mate, hopefully im not too late on this one.
R34 GT and GTT's are different..
GTT's run the GTR rear hubs and GT/V's run the S13-15 R32-R33 non GTR hubs, the one's you bought off eBay will fit any S and R chassis minus the GTR's and a 34GTT's.. the one you would need is in the link below, its what Just Jap supply but you can see the difference.
http://justjap.com/store/product.php?productid=19774&cat=375&page=1
I hope this helps as most listings for rear wheel bearings miss this very vital piece of info.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
