********BRIDE CUGA no rails (includes sliders so you just need mounts)- a grade- great condition - $800 firm
********R34 GTR VSPEC 2 front and back seats in GREAT condition. very rare and comes in black. looks great., only 250 sets ever made! - $2700
********EXEDY heavy duty clutch came out of my RB26, can handle up to 400kw. plenty of meat left (upgraded along with rebuilt) - $400 ono
********RB26 OEM cams in good condition - $200
********ADVAN RG - forged lightweight 17x8.5 all round. had them on my gtr. will come with rubber at about 75%. All in good condition with only mior rashes - $1300
********rb26 High flow turbos (requires rebuild) comes with after market dump pipe - $200 ea ono
******** PAIR Enkei RPF1 18x9.5 + 15 in silver, great condition, pretty much brand new $600ono
Located at canley heights NSW. prefer pickup pls text via 0426876899 as i rarely check emails
Edited by nltd
no. not original otherwise id be asking for $1600+ . they are grade A replicas, with bride tags and logos on every part. so its a pretty damn good rep.
Pls pm me ur number in regards to photos. they are all on my phone
  • 3 months later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
