parting out my r32 4 door as i have decided to build a s13 as the 4 door body is to bent.
selling everything off it minus motor, gearbox wiring hubs and rear diff. wheels are not for sale
both guards, tail lights, indicators, headlights, front bar and reo, rear bar, glove box, plastic trim that goes around gear stick, dash vents, front seatbelts and c pillar panels are all sold.
Bonnet has one or 2 small dents and clear coat starting to peel in one spot. $60
Front doors pretty gc, $150 each minus door cards
rear doors both have dents. $50 each minus door cards
rear reo bar gc. $50
dash has some bubbling $60
boot lid has scratches and dents $30
rear seats would be pretty good with a clean $30
passenger seat gc $60
LF door card in good condition no switch. $50
RF door card not so good missing abit of material around handle $30
rear door cards in gc $40 each or 70 for both
centre console gc $40
dash has a bit of bubble on left side $50
only got drivers a pillar panel has 2 tears in it $15
drivers master window switch, everything works good except LF switch is sloppy and will only wind window down $50
Straight through 3" cat back exhaust with cannon i think 4" outlet has been dragged on ground a few times $140
shell will be for sale once it is completely stipped unless i get a good enough offer now.
Prices are negotiable, heaps more parts let me know what your after.
can msg more pics if wanted
0434950923
Located on the sunshine coast qld 4556
https://www.sau.com.au/forums/topic/429687-wrecking-4-door-r32/
Hey,
Ill take the rear door cards (both) posted to 7315, Tasmania. Will pay for postage of course.
Also im after:
1-DASH STEREO SURROUND: example; http://www.ebay.com.au/itm/JDM-Nissan-Skyline-R32-Stereo-Gear-Surround-/330913215143?pt=AU_Car_Parts_Accessories&hash=item4d0bf6f2a7&_uhb=1
2-Bonnet Latch and Cable
3-Front parking/indicator lights (pair) without cracks/chips. example: http://www.ebay.com.au/itm/NISSAN-SKYLINE-R32-GTR-GTS-SMOKED-CLEAR-CORNER-LIGHTS-INDICATORS-RB26-RB20-nismo-/221197912270?pt=AU_Car_Parts_Accessories&hash=item33806c48ce&_uhb=1
Edited by waterbirth
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
