R33 GTS-T for sale
Have owned this car for 5years and done a fair bit of work to the car,
Twin Scroll GT3037 with external Tial 44mm, 3 1/2inch system ( no droning)
Power FC, 1000cc injectors, runs E85, NPC clutch etc
Car has a good setup, response and well over 300kw's.
Have a build thread showing more detail, AngryRB's StreetSweeper, also on carsales.com here
https://member.carsalesnetwork.com.au/seller/myads
Reason for selling- change of work and car spends most of its time in the garage so im after a more practical daily.
Looking for $12500
0466 257 118
Note- NO LOOKING FOR SWAPS OR LOW BALLERS
post-70965-0-87254400-1375839809_thumb.jpgpost-70965-0-87157600-1375839838_thumb.jpgpost-70965-0-42959900-1375839858_thumb.jpgpost-70965-0-78869100-1375839933_thumb.jpg
Edited by AngryRB
https://www.sau.com.au/forums/topic/429883-r33-gts-t-300kw-for-sale/
Someones going to have fun when they buy this.. lots of giggles to be had, its been spinning up third gear with roll on's
$3000 Twin Scroll setup is better than the other 300kw setups...will book it in for a dyno graph soon when tuner has time.
Edited by AngryRB
Looking forward to the graph mate and you did a stellar job of putting this one together! I tell plenty about it :)
NOOOOOOOOOOOOOOOOOOOOOOO don't sell it.. I love reading up about crap you do to it :(
You'll regret it, trust me.. then you'll end up buying another R33 just to start all over again (yes has happened to me)
yeah your probably right, maybe I should keep it and track it for a few years :P
ive started to get excited about an XR6 turbo or a VY ss to start modding.
Edited by AngryRB
yeah true.. they look like a bit of a boat but id like to have a stock car again that I can insure for theft and that's newer.
will consider returning it too stock soon.. :/
Down down prices are down... lol
Nothing wrong with this car at all, has some brutal torque delivery, it spins the wheels in third and is quite torquey as low as 2500rpm..
so a lot better than a gt3540.
$10k................. no rwc and one month rego left
Edited by AngryRB
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
