Hi all,
I have an White r33 gtr for sale, 112,xxx klm on the clock.
When I got the car the bottom end was stuffed so I am in the process of building another engine for it.
Another bottom end has been used with a fresh rebuild, (rings, bearings, hone, new seals, reshimed head, gates timming belt).
The car has r33 gtr wheels on it with new tyres (245/45). Coil overs, boost guage, and 3.5" exhaust with tuned y-pipe and split dumps.
Stock turbos that have been port matched with the manifolds,
car also has an aftermarket front bar, (not sure what brand), and H1 HID lights (low Beam).
The engine is still being put together at the moment and will be run in before sale.
If any one is interested in the car and would like to see the engine before its is complete you can contact me and we can arrange something,
im asking $20,999 ono with rego and road worthy.
Located in Brisbane.
Thanks
https://www.sau.com.au/forums/topic/430065-r33-gtr-1995-white/
Some more details
Acl race series bearings used on both big end and mains.
Oil restrictor in block.
Standard oil pump
Standard water pump
Standard Rb26 Pistons and Rods, with Genuine Nissan rings.
New gaskets and seals.
All valve stem seals replaced.
Valves reseated into head.
Head decked.
Block honed
Standard head gasket.
Gates timing belt.
Stock injectors and computer.
Hks Tuned length y-pipe
Split dumps,
3.5 to 4" exhaust
Tanabe Coil overs, fully adjustable.
Pivot boost gauge
Excellent condition interior.
Brembo brakes.
Pics are on there way...
  • 1 month later...
Hi all, bit of an update.
Car is running and will be registered this week then off to the dyno for a run in.
still waiting on a few parts to finish it of but I am still open to people coming to have a look if they are interested.
Hi all,
More pics are coming soon, waiting on a new front grill, and a polish.
I will be open to offers including cars for trade.
I would be open to 4 door 4 cylinder cars preferably turbo. (eg, WRX, Evo, GTIR, VW GTR, Liberty or A4 Audi.)
I will def consider others also.
thanks
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
Hi all its been a while.
Price drop to $19 900. to any one interested I will look at offers also.
Just had a rear wheel bearing replaced also.
Edited by Muff
Hey mate was just wondering if you were considering swaps?
2005 bf xr6 turbo. Has 320rwkw, 6 speed sports shift auto, clean, has almost 160000km comes with spool rods, cp pistons, arp studs, big actuator. Has a full exhaust, valve springs, injectors, fuel pump, oil feed line, zip kit in gearbox for firmer shifts, DVD player installed but haven't made the appointment for it to be wired up yet, gauges on dash, plazman 800 cooler, hot side cold side pipping, currently running on 13psi. If motor is built (parts supplied) it will handle 1000hp claimed by spool. Vic rego until November.
  • 3 weeks later...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
