Hey guys so my r33 switch light dims when i close the door rather then turning off! And when i open the door the light brightens anyone else had this problem! Issue cause its snnoying having to turn the light on when getting inside the car so i can see at night!
https://www.sau.com.au/forums/topic/430127-help-r33-s2-roof-light-switch/
They all dim when you close the door. I don't get what you mean by the light brightens when you open the door? Does the light turn on straight away or it takes a while to get bright?
It sounds normal to me.
About 10 seconds. I will look at a wiring diagram and see what I can find. It could be high resistance across your door switch or the control module.
Also interior light has three settings, "Off", "On", "Door", make sure it's only set to "Door" and not "on" all the time...
If at "On" it may not be full brightness as it may have not so good of a ground, when the door open it brightens as the door allows a better flow of electricity.
Replace the globe/s or LEDs and while your there take the whole unit out of the roof. While out make sure all the contacts are fine.
- Disconnect the wiring harness from the back of it and then re-insert it. You could quickly clean the contacts it plugs into.
Taking it out is easy. Gently pry the clear plastic off. Inside is 2 screws - remove. It'll drop down. Unclip it. Clean contact points and replace globes.
Clip together and test.
2-5 minutes.
Edited by Sinista32
^^^^ That would help if it didn't work at all. The light does come on so that proves the circuit is working and the contacts will be clean. If the contacts were dirty then you would have no light at all
Wiring diagram.doc
Hope this helps does it turn off once the car is started or the key is in.
I still believe its the entry control unit
There will a constant 12v on one side of the globe and the control unit will supply the other side with a negative via the doors which has to go through the C/U
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
