A couple of Items I don't need...
1) Apexi SAFC 2, Silver with Blue screen, some marks on the screen but shouldn't obscure the screen when switched on, loom has been shortened.
$220 Posted anywhere in Aust.
I accidentally won 2 of these on Ebay so 1 has to go...
The other is Black and in better condition. I'm not fussed which I use so if anyone wants the Black one it's $250 posted in Aust.
2) A Metal AirBox similar to an ARC Box. I bought this under the impression it was for a 33 GTS-t but the angle is not correct where the AFM attaches. Not sure what it's for then but with some Silicon Elbow action and Bracketage, it will likely fit whatever you want...
Has a Shabby looking Filter in it but also comes with a used ARC Foam filter.
$150 Posted in Aust.
post-78856-0-59615600-1376307356_thumb.jpgpost-78856-0-30396400-1376307353_thumb.jpgpost-78856-0-35610600-1376307349_thumb.jpg
Cheaper for pickup in Canberra. Items are NOT NEW.
PM or Post interests...
Cheers.
Rob.
Sorry mate, Black is no longer available as it is installed and tuned. :woot:
(meant to update this)
You can have the Silver for $200 Posted.
Airbox $130 Posted.
That it would. ^^^
Would look better if it was in someone's fine Automobile. :yes:
Silver SAFC 2 $200 Posted.
Metal (ARC Style) Airbox $120 Posted.
Airbox may be for Silvia... Looks Very Similar to an Autobahn88 one from Performance Wise --->> http://www.performance-wise.net/page56.htm
$120 Posted with 2 filters is Less than 1/2 the Price of a Newy... :whistling:
$200 Posted for the Silver SAFC 2.
Airbox may be for Silvia... Looks Very Similar to an Autobahn88 one from Performance Wise --->> http://www.performan....net/page56.htm
SAFC Now on Ebay ---->> http://www.ebay.com.au/itm/261278772860?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649#ht_312wt_1245
Less than 24hrs left on Ebay.
SAFC on Ebay ---->> http://www.ebay.com....9#ht_312wt_1245
Airbox also on Ebay ---->> http://www.ebay.com....9#ht_259wt_1245
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
