You could always try that new invention where you type a question and it find stuff for you.....
I think its called Google? :blink:
http://www.stgeorgetyres.com.au/xxr-962-rims-and-wheels.aspx
https://www.sau.com.au/forums/topic/430293-xxr-rims/#findComment-6971499
"gerz" here on SAU is an agent.
They're a nice looking rim - quite light and supposedly strong.
Got these through him.
* I wasn't home to receive them from the courier.
One of the rims has pit holes > I'm not sure of the integrity of this cast rim now.
XXR would not honour their warranty.
I placed the rim on the rear.
There was no delivery docket to sign, even though I was told I shouldn't have signed it nor accepted them.
* You should open the boxes and check each rim thoroughly before accepting them!!!!!!!!!!!!!!!!!!
Just be careful.
https://www.sau.com.au/forums/topic/430293-xxr-rims/#findComment-6974436
Just be careful.
That is quite true! Hopefully its nothing serious Terry.
  • Like 1
https://www.sau.com.au/forums/topic/430293-xxr-rims/#findComment-6975685
Thanks Chris...
No problem whilst knowing that I still have Enkei for the track, as ARAB alluded to below.
.... a set of enkeis and have proven wheels that won't disappoint.
Your car your choice.
https://www.sau.com.au/forums/topic/430293-xxr-rims/#findComment-6976327
Thanks Chris...
I guess that does somewhat help the situation knowing you have a sturdy set of rims for when the time comes.
https://www.sau.com.au/forums/topic/430293-xxr-rims/#findComment-6976612
  • 9 months later...
Thanks for the shout out 34GeeTeeTee, we are offering amazing deals on all xxr wheels and tyre packages. Also even if your just after some advice on tyres send me a pm and i will be more than happy to lend a hand. We specialise in most tyre and wheel brands.
St George Tyres
https://www.sau.com.au/forums/topic/430293-xxr-rims/#findComment-7291773
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
