Bought a secondhand Nistune the other week.
Plugged it in the other day and had the map adjusted etc, all works well.
However, it's failed to start twice so far! When you turn the key to start, it cranks but doesn't fire. The fuel line doesn't pressurise, and it won't start.
The first few times, turning the key back a turn and then trying again resulted in the fuel pump coming up to pressure and starting no problems. This morning after 20 mins stuffing about I put the stock ecu in, and it fired first crank.
Is this a setting problem within the Nistune or a problem with the ecu?
Plugging the Nistune back in once it cranked over resulted in it firing first go too - which confuses me!
It's really weird! I HAVE to turn the car onto Acc then back it off, put the key back in then turn to Acc again and I can hear it prime, then I fires first crank
I guess it's a handy security feature!
Been in touch with Nistune, its a known issue with a batch of the boards they used in the R34 ecu, and they will repair it for me. Hopefully that fixes it
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
