www.meisei.com.au
I was shown this site by my friend at work. He said that he's going to import from them right now. From what I can see the site is cool, easy to find the car you want, and has very nice large pictures for each one. I reckon the site is heaps better than anything I've seen.
It seems as though around Wednesday is when most of the auction cars are in, there is even an R34 GTR M-Spec available at the moment - hot!
=search&formdata[filter][chassis]=BNR34&formdata[filter][search]=t]http://www.meisei.com.au/index.htm?formcod...lter][search]=t
There is heaps more cars to check out, I sometimes lose track of time.
https://www.sau.com.au/forums/topic/43063-new-import-site/
I like Meisei's approach to searching and higher image qualities - especially for the auction cars.
Having access to better and higher resolution images means I can make a better call on getting a car that I want.
And the cost calculator is very comprehensive, it has all costs right there for one to look at - it's impressive.
https://www.sau.com.au/forums/topic/43063-new-import-site/#findComment-884789
It is all about the person in Japan buying the car,
If you are going through all the trouble you want the person who buys the car to inspect it in person or through a contact.
They need to read japanese for the auction report but not to buy it just off that info as some people do.
Those high resolution images are just the better ones off past auctions or from www.japanautodirect.com have a look at www.j-spec.com.au and you will see what I mean with auction photos.
It is like everything in life you pay for what you get, so do the research, talk to the Raws workshops in your area ask for anybody they can recomend to buy cars for them. They comply the cars so they know who buy's the good cars and who buys the shitters.
The membership fee is the same as paying J-Spec the brokerage fee so it is the same thing different name,
One last thing the current exchange rate is .76 cents and their converter dosent go that low so it will cost more.
Look at Performance Forums where J-Spec sponsors and lists some cars, just do your research, Saying what they want to do is different to what we do.
https://www.sau.com.au/forums/topic/43063-new-import-site/#findComment-884876
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
    • Haha, that's so true. Minimal plans quickly turn into a full transformation, especially when you see what others are doing
