Congrat's on running in the 10's mate! Solid terminal speed too.
I'm hoping to have similar potential and will have the extra capacity very soon, minus the 4WD.
Yes mate.
Not 100% sure yet, might refit the larger Stage V turbine housing and wheel that my current T62-1 came with. I downsized to the Stage 3 as it wasn't as responsive as I wanted at the time. The extra capacity should solve that issue and give more top end. A small increase in peak power is enough to keep me happy - low-mid 400. More torque across the board is what I really want.
The other option is a Garrett GTX or something similar but yet to do the research.
Forced performance HTA range is a better option than Gtx, same or more power than gtx with better response
Id be listening to Andrew^^, they sound awesome,, pity they only started to biggish stuff, otherwise id definitly try out there 76mm gt42
cheers
darren
Hey Darren, been a while mate! Was chatting to Rob earlier in the year and asked how you were going and what you were up to.
I am very keen to go down the FP HTA path now thanks to the input from Andrew and yourself. Cheers.
matt,
Theres a heap of results on the evo forums from USA, they make some big power on high boost and run into the 8s down the 1/4mile...
Whats getting done to your motor, what head?
Edited by sky30
