Hi everyone,
Once again the shed has been cluttered by parts that I no longer need. All parts cam from either R33 GTR OR R33 GTST. All parts are quality goods which are straight and haven't been in any type of accident. The parts themselves have been replaced by new pillow ball suspension and there isn't a need for me to have the stock stuff anymore.
I'm located in Adelaide, South Australia and can post the items if need be at the cost of the buyer.
-oil cooler (push on hose type) $15
-GTR air idle regulator $15
-GTST diff centre (minus ring gear $100
-Generic 12' thermo fan $40
-GTST S1 HICAS rear steering unit $80
-GTST S1 camber arms front $10 each
-GTST callipers and rotors $200 (front and rear)
-GTR vac ballast tube $10
-GTR vacuum/water lines $10
-BLITZ blow off valve $50
-TRUST/GRACER pod filter $20
-GREEN label air flow meter S1 GTST $20
-GTR rear main crank seal $5
-GTR crank scraper plates $10
-GTR water pump (no cavitation) $10
-GTR DUMP PIPES $15 EACH
-GTST washer bottle and motors $15
-GTST rear camber arms $5 each
-GTST rear traction rods $5 each
-GTST rear LCA's $15 each
-GTR turbo oil and water lines $5 the lot
-GTST full exhaust from dump pipe $80 (mild steel)
-GTST A/C lines +condenser $30
-GTST S1 centre grille $60 (2PAk silver)
-Bosch 464 fuel pump $5
-GTR thermostats (76.5 deg) $5 each
-GTST fuel tank $30
-GTST fuel pump assembly $40
-RB25 GTST S1 gear set $300
PICS BELOW!
YOU CAN PM ME ON HERE OR MSG/CALL ME ON 0400262578 IF YOU NEED ANY MORE PICS.
CHEAPEST PRICES I HAVE SEEN ON HERE FOR STUFF LIKE THIS..
CHEERS HULI
post-61756-0-19006600-1377864302_thumb.jpgpost-61756-0-24336900-1377864327_thumb.jpgpost-61756-0-16104100-1377864352_thumb.jpgpost-61756-0-55146300-1377864368_thumb.jpgpost-61756-0-86390900-1377864388_thumb.jpgpost-61756-0-42353800-1377864408_thumb.jpgpost-61756-0-60663800-1377864452_thumb.jpgpost-61756-0-37012600-1377864489_thumb.jpgpost-61756-0-60846000-1377864517_thumb.jpgpost-61756-0-82848700-1377864557_thumb.jpgpost-61756-0-39246000-1377864584_thumb.jpgpost-61756-0-61449100-1377864604_thumb.jpgpost-61756-0-36002000-1377864627_thumb.jpgpost-61756-0-49896800-1377864653_thumb.jpgpost-61756-0-05722200-1377864678_thumb.jpgpost-61756-0-20533500-1377864699_thumb.jpgpost-61756-0-05209900-1377864732_thumb.jpgpost-61756-0-36502800-1377864768_thumb.jpgpost-61756-0-93670900-1377864791_thumb.jpgpost-61756-0-02471000-1377864826_thumb.jpgpost-61756-0-95232000-1377864851_thumb.jpgpost-61756-0-77871600-1377864879_thumb.jpgpost-61756-0-59137100-1377864908_thumb.jpgpost-61756-0-21735400-1377864934_thumb.jpgpost-61756-0-84312300-1377864951_thumb.jpgpost-61756-0-32548800-1377864992_thumb.jpgpost-61756-0-32548800-1377864992_thumb.jpgpost-61756-0-54981700-1377865021_thumb.jpgpost-61756-0-67487300-1377865118_thumb.jpgpost-61756-0-67487300-1377865118_thumb.jpgpost-61756-0-42451400-1377865158_thumb.jpgpost-61756-0-39339300-1377864145_thumb.jpgpost-61756-0-48789800-1377864232_thumb.jpg
https://www.sau.com.au/forums/topic/431080-r33-gtr-and-r33gtst-parts-cheap/
  • Replies 42
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
