Can anyone let me know which ECU pins the knock sensors for an RB20Det R32 ECU are and what ohm resistor I need to bridge them out? I have been getting timing pulled randomly for no reason when cold, it has only started happening with the winter ending and no actual audible knock, which I highly doubt as the car is running slightly rich and retarded already and I barely put my boot into it when cold.
I have already added most of the timing back to the cold start maps, it is fine when I start the car stone cold, then about 2 mins into the drive it will pull a lot of timing down low (probably a different issue) but also then across the upper rev range as well it feels like it is running on the knock maps (I have 3 degrees less on the entire map here)
Do not have a nistune license otherwise I would just nuke the knock maps.
Thank you.
edit: apparently I require a 500 ohm resistor, can anyone confirm? I guess I could just put a multi meter on the sensor to test.
Edited by Rolls
  • Like 1
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
