Hey everyone
Like the thread topic states..
My left and right indicators on the headlights aren't working but the rest are.
The globes are fine, and when I test to see if any power is in there, there isn't.
The fuse under the dash is fine. Ive got the relay pulled out atm.
How would I know if my relay for my indicator isn't working, and if ive gone in the wrong direction please guide me.. kind of lost
Cheers OJ
https://www.sau.com.au/forums/topic/431111-another-indicator-thread/
Swap it with another relay in the relay box. Make sure they are the same by looking at the specs on the top, they should all be the same anyway.
Other then that if you have checked all the fuses already you will just have to keep testing for power. Indicator stalk may be shot. Because the high beams run through it I assume it may have an affect on the headlights and indicators.
Okay I guess I didn't realize yesterday, but my parkers dont work either.
High beam works
Low beam works (only when clicking into 2nd mode)
Indicators next door to the headlights don't work at all.
The previous owner did have HIDS on and took them off.
I can't really follow the wires back from the globes as they get hiding. Still trying to find a suitable 3 pin relay as most in the car are 4 or 5 :/ unless I pop down to supercheap..
So the low and high beams work normal once the light switch is past the park light setting and into the headlight setting? park lights arnt blown or removed or anything like that?
Most of the time HID conversions are pretty easy to get back to standard as most of them use the standard wires as trigger wires for the ballast/relay for the HID's, but at the same time it comes down to who installed them
Have you checked the flasher unit for the indicators? I swapped mine not long ago to a non load dependant flasher (because I put LED indicators all round) and i hooked it up wrong the first time and blew the fuse. So you've checked all the fuses but perhaps something has happened to the flasher unit
The only problem is that because it wont work it will be a bit of a pain to find because there usualy easy to find when you can hear them clicking on and off. Mine (in my r33) was under the steering wheel, could get to it if you stick your head in the foot-well and look up. 3 wires going to it
  • Like 1
Correct, lows and high beams work after the park light setting. Park lights have globes and are not blown due to being checked.
i also checked to see if any power is going there, but there isn't.
isn't the indicator relay the flasher unit? i have attached a photo of what makes the 'clicking noise' when the indicators are on Left or Right (which is fast), or on Hazards (which is slow). But either way, the front left and right indicators aren't working nor are they receiving power.
when i unplug this unit, (which is a 3 pin) the indicators don't work at all (obviously), when plugged in, it makes the clicking noise.
This unit is under the driver side, pretty much inline with the clutch pedal bolted. i just have mine unbolted at the moment.
im in the process of buying a new indicator stalk, as i have a feeling it could be short, as the previous owner said it could be the reason for it flashing fast.
Is the process of the indicator lights going on like this:
  • Left or Right indicator selected from the stalk
  • goes to indicator relay/ flasher unit (3 pin)
  • then travels all the way to the selected side indicator globe?
Ps. the photo is up side down, only rotated is for reading purposes.
Edited by Skyline_034
Ah ok, mine has both a flasher and a relay I think.
I think this is the one I replaced my stock one with anyway, stock one looks similar (round, about the same size, and a 3 pin plug):
Perhaps the 32's are different but worth a look if you have 10 mins or so to look under the steering area
BTW, the hazard lights dont work by chance do they? The indicators and hazard lights are funny, indicators wont work without the hazard switch plugged in but the hazards work when the indicator fuse is blown. From memory on my car this is true anyway
is yours a series 1 or 2 r33?
cause mine is a s2 r33. i wonder if there's a difference in this =/
ill check it out tomorrow after work, as ill have a better look at it during the day.
yeh the hazards work fine, clicks normal (slowly), but still the parker indicators next to the headlights have no power.
Oh crap. Sorry for some reason I thought you had an R32. Mine is a S1 R33
So the flasher should be there, its def there on mine. I can possibly get a photo later if you think that might be the problem. Should at least be able to test it for power see whats happening
Also, the small bulbs in the side of the headlights are just park lights not indicators. They should light up when the park/head lights are on.
The indicators are on the bumper and the front guards.
Nah all good man, we all make mistakes.
I'll check tomorrow after work, my roof lights don't work either, it did but dunno. I know the middle light is a blue led globe and can't find power to it, but not to worried about it at the moment.
Oh my bad, I thought there was 4 lights that would flash for indicators including the ones on the front bumper (fog lights)
Now I'm a Lil confused, I just don't understand why the indicators are flashing/ clicking flash then if they are not connected to the low/ high beams?
Yeh if it's okay, could you take a photo and upload it so I can see where it should be. At least if it helps me, hopefully help out other SAU members too.
Cheers man
I should also add, when I switch to 'park' mode on the stalk, so one click over. My clock and dashboard lights dim down as they should, but like I have written no power to headlights/ parkers.
Apologies for not writing this earlier.
Hey everyone!
I've fixed the problem, anyone that has this problem remember to check the bulb size for indicators.
My front indicators had 10mm wedge globes, and I put 15mm wedge globes and that fixed it.
Cheers everyone for the support, help, and solutions. Surely learnt abit more about skylines and electrical lol.
Thanks,
OJ
/closed
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
