A mate of mine is parting ways with his awesome project car.
It's up on eBay (check for more pics) but here's the rundown.
Looking for 16k but he's open to offers.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=281160076709
Big Block Ford Engine 485 cubes
Original 460 motor
FMX Stage 2 Transmission
Stall Converter by The Converter Shop 8 Inch Billet Backed 5500RPM
460 Offset Crank
Machine work
Weiand Tunnel Ram (HPC Coated)
Tunnel Ram Linkages NEW
Twin 660 centre squirters by RAYJE Carburettors. (Rebuilt and not used)
Carbie spacer plates
Carbie Bolts
Edelbrock Aluminium Cylinder Heads
Custom Race Valves
Crower 3/8 custom racing push rods
Iskederian Springs
Crow Locks
Comp Cams Retainers
Screw in Studs and Guide Plates
Yella Terra Roller Rockers
TRW 12.5-1 Forged Racing Pistons
Super Cobra Jet Con Rods
ARP Rod Bolts
Clevite Bearings
King Bearings
Bullet Racing Flat Tappet Camshaft
Comp Cams Flat Tappet Lifters
Hilborn Fuel Pump & Belt drive
High Energy Sump Super Pan
High Volume Oil Pump
System 1 Oil Filter Aluminium with reusable inners (made in USA)
Chrome bolts with Ford logo embossed on them for whole motor
ARP Flywheel bolt, V/cover stud set, molly oil pump driveshaft, distributor stud
Ford gasket kit
MSD Distributor part no: 8577
MSD 6AL Ignition part no: 6429
MSD Blaster 2 Coil
Moroso Over flow bottle
Moroso Rocker Covers
CVR High performance Billet Water Pump
Aluminium Timing Cover
Castlemaine Rod Shop Engine adaptors (engineered) Cleveland eng mounts to BB460
Engine is basically all new and not been used.
Minor things to finish motor like attachment of crabs, water pump, Timing cover, rocker covers and buy some headers.
Spares
I have a couple of boxes of various bits like harmonic balancer, braided vacupan hoses
Basically the whole engine is brand new and not been used except for the crank and cam.
Engine builder said Motor size: 485ci and Approx HP: 620 – 650
Car
Brand New
Paint (even the inner guards painted with 30 odd hours to prep them for paint. Silver with blue pearl
New Interior Carpet, Seats, door trims, hood lining Dash re skinned and all plastics painted
Roll Cage from Andrews Race Cars Sydney
Chrome Trim polished
Pedder’s Front end suspension, tye rods ends, idler arms, ball joints and bushes, rubbers everything Nolthanathe some in blue to match the car.
Rear Brake drums rebuilt
All suspension sandblasted, powder coated pearl blue, silver & Black except idler arms black
Strange full spool
Fibre glass boot lid
Undercarriage painted in black
New front disc brakes powder coated
B&M Pro ratchet shifter
5" Tacho
Blue & Silver Steering wheel with new Boss kit
Mickey Thompson Sportsman Pro Tyres
Other Items
Tubbed rear end by Taverna Chassis
Tubbes, parcel shelf & Spare door panels all Aluminium with pattern pressed in
Shortened 9” diff 31 spline axle
Richmond diff gears 5.14
Centreline convo pro's 15X14 rims
Centreline convo pro's 15X3.5 rims
Mickey Thompson street tyres rear 29X15.5X15
Moroso Trick Springs
Competition Engineering by Moroso Ford racing shockers
Chrome master cylinder
Tail shaft
Transmission Cooler
Radiator
CD/DVD Player
7” Pop out in dash LCD TV Screen
FMX Gearbox
Plastic race Seat
This car is straight and no rust.
Spares
Steel boot, Aluminium custom internal door panels with pattern pressed in same as rear stuff, Tails shaft and more
As you can see it is not a standard car anymore plenty of hours and money gone into it.
Will make a very nice Show or Drag Car.
Needs
Front & Rear Screen, Rear quarter glass, Brake & Fuel Lines, Tubes for Rear Tyres, Fuel Cell,
Wiring (Electrical)
And some finishing like putting screws in interior plastics, Aligning doors
Phone for any questions 0435 658 832
It's a good rig, it has a lot of potential.
It will be a shame to see him sell it.
If you can think of any of your mates who would be interested by all means pass it on.
Biggest issue is cops, none of them are into show cars really. I built mine first, then 2 others built tubbed big block XD's, there were 3 getting around in Frankston in the early to mid 80's........we even ran wheelie bars, it was a different era lol
Yeah that's the tough part.
Even when I got my first performance car it was a different era, we got away with heaps by comparison with today's standards.
It's very anti-enthusiast now days, and why not when you can make so much revenue fining people for bullshit.
mmmmmmm craaaabs
Yeah I noticed that in his post lol.
Noticed too late to fix it though, so crabs it is :D
Who needs carbs when you've got crabs to pour in fuel for you.
  • Like 1
  • 1 month later...
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
