Mugabetown - Whoretownin' At It's Worst.
Panel gap and the batman... Pretty sure it's nick...
I'm B@man
Errrr excuse, but do you have a RWC for this vehicle?
I'm B@man
Well as a matter fact I dont mr officer............................why is that (officer asks)?
'BECAUSE ITS A FKN BAT-MOBILE"
...I'm B@man
so let me understand this correctly...........................if a mod / admin is an bad mood they take the banning stamp out and slap you in the face with it :blink:
Yai - to being banned for genuinely breaking the rules
No - to being banned just because you someone can ban you
You understood it just fine. People seemed to take it with much better humour. People are a bit self important and precious about the forum these days.
Since when did Ben Affleck join the forums?
No, Bad Tony
Indeed...I'm B@man
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
