Mugabetown - Whoretownin' At It's Worst.
Pub in the home...gah!
Tap king makes this possible, I am taking lots of on call work at the moment though, this also cuts into beer time
My car will be done before yours at this rate!
Just jinxed your self!
don't believe in that crap! Everything happens for a reason. Whether that reason is fair or not is another story.
I'm starting to find out that if you let things slide nothing gets done.
It appears that you have to fight for what you want theses days.
As for Tap King, gimmicky idea that has been well marketed this time around. Didn't work so well when they tried it with Heineken a few years back.
If you want REAL tap beer in your home you should go talk to these guys http://www.brewsbrothers.com.au/
When I had more time on my hands (and a housemate who loved to drink as much as I did) we did bottled beer with them. $150-$180 for roughly 6 1/2 to 7 cases of whatever style of beer you wanted.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
