Mugabetown - Whoretownin' At It's Worst.
If a crank trigger could work easily with the stock ECU or PowerFC I would defiantly be blowing up the CAS
Yep they appear to cause their fair share of headaches.
After Bunta (Andy) explained to me the inherent issues associated with them - having a crank trigger setup is almost just logical really.
So nearly killed my engine today
Had danger to manifold on the HUD and warning sounds and sirens and lights and I looked like this
Posted Image
But seriously nearly killed it
What did you do to it?
Silicone hoses yesterday. And boost tee. grandad took my radiator cap off didnt out it back on all the way
Went to supercheapauto this arv drive it like a granny so no boost whole way
Put tee on.
Driving home pulling over and adjusting
Got in.... Drove... Looked down..... Temp was all the way up
Pulled over waited like 30 topped it up and grannied it as fast as I could all the way home
It's in driveway cooling as we speak so I can too it up then go tell my grandad he owes me a vr38
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
