Mugabetown - Whoretownin' At It's Worst.
1 is too many
You used to be cool...
This! Also I am now the proud owner of a less than mint condition silver au falcon 6cyl auto :P
You were never cool.
Only thing they are good for is room and highway cruising
Skids! Auto falcons are most excellent at skids.
Yeah, if I owned that POS I wouldn't want to drive it either...
Oh I am so keen to throw scissors at you.... So keen. And then giggle my ass off all the way around the first corners of qr at 80ks an hour
I bet $20 that the wedge hammers nicks abomination around qr - again.
6 months from now ill bet anyone 50 bucks I blow the absolute doors off martins glorified door stop down the main straight of qr
6 months from now ill bet anyone 50 bucks I blow the absolute doors of martins glorified door stop down the main straight of qr
I did say "around qr." it's ok, the ant eater will be ready by then. :)
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
