Mugabetown - Whoretownin' At It's Worst.
6 months from now ill bet anyone 50 bucks I blow the absolute doors off martins glorified door stop down the main straight of qr
I'll take that bet
but I won't be slowing down to let you catch up after going round turn 6 :P
What, so it's only a race if I slow down to make up for your car's inherit weakness?
:down:
You should be great full I'm even taking my car to qr...
If we were in the wild, I would attack you. Even if you werent in my food chain, I would go out of my way to attack you! If I were a lion and you were a tuna, Id swim out in the middle of the ocean and freakin EAT YOU! And then Id bang your mum.... That's what I prove by taking the abomb to qr
Would be more impressive if you were the tuna and he were the lion...
Agreed but Martin looks more like a fish lol
Martin be a sport and turn into a fish, mike will pay u in back rubs lol
OK, first off: a lion, swimming in the ocean. Lions don't like water. If you placed it near a river or some sort of fresh water source, that make sense. But you find yourself in the ocean, 20 foot wave, I'm assuming off the coast of South Africa, coming up against a full grown 800 pound tuna with his 20 or 30 friends, you lose that battle, you lose that battle 9 times out of 10. And guess what, you've wandered into our school of tuna and we now have a taste of lion. We've talked to ourselves. We've communicated and said 'You know what, lion tastes good, let's go get some more lion'. We've developed a system to establish a beach-head and aggressively hunt you and your family and we will corner your pride, your children, your offspring.
  • Like 1
i just left. i dont wanna come back for a while. although i enjoyed it, the bogan was strong.........
Bogan hasn't even started yet, wait till I sau sticker up my new falcooooon
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
