Mugabetown - Whoretownin' At It's Worst.
Indeed I did.....still wouldnt drive it by choice. but for the price...i guess you cant argue. would still go for the Hatsu or similar small FWD cheapness instead. I miss my Madaz i find this hard to Believe. But then P platers are pretty bad at driving :) I assume you mean newer? to me an old car has a Carby :thumbsup: night Ants, hope to see it out and about soon.
lol yep. Meant 5 years newer. Yeah hopefully the car will be ready this week :)
Morning all, T minus 59 mins and counting to tooth extraction....
Why? The mazda makes a few kw more and the same torque and is only a smidge heavier. It also has no lag. Which I think was the deciding factor.
sorry I read Mk.V.
correct, but P platers still suck at driving :)
That sucks major balls! I hated having my wisdom teeth removed, mine hurt like a bitch mind you I had two done in the chair and heard them cracking them off my jawbone and the other two they put me to sleep for and apparently I was trying to talk to the nurse about my car whilst the surgeon was trying to get my teeth out, I also woke up to find a piece of paper which I had scrawled my blood pressure on at different readings - The nurses found it entertaining, still have no idea how I got a piece of paper and a highlighter *scratches head* my recovery sucked took close to 2 months in total waa!
And morning everyone, happy (or not so happy) Monday... Came to a great realisation this morning that I can watch Initial D on youtube whilst on the cardio equipment at the gym - That was a good start to the day :)
Oh that does sound bad, I had my wisdom teeth out (and had two extra for a total of 6 :0 ) but my surgeon was awesome, i was alright in 4 days, had them out on Monday and played rugby on the Sunday with no issues. I was pretty weird recovering from anesthetic too. I woke up, unplugged my heart monitor and pulled out my iv and took my self for a bit of a walk, I was half way down the hall to the elevators before they worked out where I went!
dentist appointment tomorrow, hopefully i don't get any bad news about mine. One sort of started to poke through in the last few years, but then stopped.
Hopefull you have adequate private health cover for this because dentist = mega cost
Just rang TNT maybe it won't arrive today... Really getting annoyed about this process
welcome to my world........................were everything appears to be so slow that I feel like Flash Gordon sometimes by comparison
