Mugabetown - Whoretownin' At It's Worst.
Has anyone else noticed the pressure in their tap kings dropping?
Have you been washing the tap out? Blockage would be the only thing that would cause it to flow slower. The gas is in the bottle so should be the same all the time
Didn't see the need as I've only been using the same beer. Shall try that.
I heart chancer!
I too have 40k stuff. Have painted since I was about 10. Don't care much for the game itself. I thought your name must have been 40k related.
Indeed it is. I'm more into the painting and modeling side of things these days. Built a decent sized Black templar army and started nids and just sort of started collecting individual models and the occasional squad and spending over 12 months painting XD
Not getting any gas. No head. :/
Nothing. Bored at home. Watching tv and waiting for chants to bring me beer.
Get Brooklyn nine nine and Dad's (new tv shows out)
^ This
Dude you need to wash it. Bet contains yeast and sugar. You will get all sorts of gross stuff growing in there then getting pushed out into your first beer.
Cool. I did chaos for many years. Started dark angels this time last year. I do have a soft spot for templars!
Tau Empire is the shit
Where is the resident templar? There is purging to be done! Lol
Just grab the trusty baneblade and take emperors champion into battle for a sure win :P
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
