Mugabetown - Whoretownin' At It's Worst.
Dude you need to wash it. Bet contains yeast and sugar. You will get all sorts of gross stuff growing in there then getting pushed out into your first beer.
Cool. I did chaos for many years. Started dark angels this time last year. I do have a soft spot for templars!
BEER!
and 40K.....wow everyone plays or played it. Chaos FTW
Tau Empire is shit
Fixed
Fish faced mother f**kers! :P
:yes:
Just grab the trusty baneblade and take emperors champion into battle for a sure win :P
BORING! orks and Chaos are where its at......well when I played it was...for me at least.
Yeah it is a paid for one, If you buy a copy of windows 8 it is an upgrade from that.
So there is already an upgrade from Windows 8 that you need to pay for?
Everyone works in IT now days the Industry is such a broad spectrum of jobs and people.
soon no one will have to leave their desk :unsure:
Ladies *tips hat*
sapinin?
48hrs from now my plane should be departing :)
Hai Scott.
How r things?
Hows da family?
Hai Ants.
Things are good. Have been in Sydney since Monday. I fly home tomorrow night.
The family is doing well. Nat and Jenna are both happy, so this is a good thing.
BEER!
Fixed
:yes:
sapinin?
Yo Man!
Watching offroad racing and about to go to bed.
Have fun in Deutchland, hopefully the weather will still be good. :)
Don't tempt me to come play golf Scott...Today is shaping up to be a laptop dropper.
We've just completed renovations. Not the best time of year to play. Greens Keepers have ripped the place up lol
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
