Mugabetown - Whoretownin' At It's Worst.
Just no, Sean did not manage his workload well coming into two major events but he would not send an ECU back to Haltech to buy himself time.
More accurately, telling the customer he has sent the ecu back to haltec when in fact the ecu is still in the car ;)
Yes, are you sure you want to accuse a business of somthing that you have no real information on?
A call to Haltech would clear the whole thing up, In fact, Ants if you are reading do call Haltech and make sure they dont drill a big hole in your ECU, they have form in that regard.
FOOOD!!!!!
Early lunch, was dying, needed food... 18hrs with no food is way too long!!! (Ate dinner with a friend with kids last night so it was like 5:30pm)
On the plus, fed so mood has improved yayyyy
I never accused a business of anything, just reading between the lines...
I have absolutely nothing against Sean and or Whitey (if he is still a part of EFI or whatever they turned/merged into???), they have always been very helpful to me and I continue to recommend Sean as a tuner where applicable.
FOOOD!!!!!
Eat a snickers. You aren't yourself when you are hungry
Pretty much! I get Hangry for sure!
You know those hungry screaming children at the supermarket, I am like those but taller and more offensive language depending on the level of hunger and where you shop...
i think you should marry me!
If they have always been helpful what leads you to beleive they would do what you claim they have done
bs been working...
Legit, I was doing staff development forms and shit.
Yes...they like them some drilling
FOOOD!!!!!
Were you Hangry? (hunger induced anger)
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
