Mugabetown - Whoretownin' At It's Worst.
you know what i dont get!! is why they havent made GIANT milky ways! they are like the best ever!!!
Or white chocolate Mars Bars :wub:
i think you should marry me!
Bearer of bad news again, ZCR got in first, soz bout that.
Sup foools?
Eating, Whorin, the usual.... Oh yeah, working, right...
Were you Hangry? (hunger induced anger)
Extremely!
guess ill just have to sweep you of your feet when im up there.... :P
Have to sweep Zane off his first!
Who does she turn into?
The hulk... But pink... And I glitter bomb EVERYTHING!!! However just as angry...
Yes, are you sure you want to accuse a business of somthing that you have no real information on?
A call to Haltech would clear the whole thing up, In fact, Ants if you are reading do call Haltech and make sure they dont drill a big hole in your ECU, they have form in that regard.
Just spoke to Haltech. They have not received any ECU from EFI Performance or under the name of Sean Ramsdell.
I asked them about the drilling of holes in ECU and they told me that they only do that to demonstration / display versions for dealer workshops to ensure they are not used again in the event they are stolen.
He ensured me that they will not do that to mine (if its there)
Really, really, really, really depressed with everything regarding the car FTM.............................to the point where I feel it just wasnt mean to be :/ :/ :/
The worse part about it is if the Haltech is fked, Im not in a financial position to purchase another which means no car, no tuning................................nothing.
The worse part about it is if the Haltech is fked and Im not in a financial position to purchase another which means no car, no tuning................................nothing.
dude ill lend you my adaptronic if you want? my car is in garage not being driven so you are welcome to use until u get sorted
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
