Mugabetown - Whoretownin' At It's Worst.
With the introduction of allowing R rated games they can't exactly b sn it for that and with the amount of studies proving the games don't make people violent they have no cause to do so.
R rated games is less of an issue than you think. Before R rated games were a thing there were less than a dozen games that were refused classification and of those most had some minor tweak to get it past the censors (e.g. changing the name of one item in Fallout 3/NV so it doesn't reference morphine, stopping you from beating hookers to death after hiring them in GTA3 etc)
The main reason the R rating was pushed by industry groups was to stop little timmy buying it, not to allow for more graphic content.
As for the studies, well they are actually inconclusive. For every well designed study finding no correlation between violent games and aggressive behaviour there is another that does find a link. Playing a violent game may not make you a killer, but it may exacerbate underlying issues. This isn't unique to games however, it applies to all forms of media consumption. Why do you think they put helpline numbers on every news article about suicide? Because reading the news article may tip a severely depressed person over the edge.
Average beer is average.
I'd be happy if I had more than 2 choices of black beer at First Choice.
I care not for your beer opinion anymore. I like it, everyone else at work likes it so take your booze snobbery else where :P
Not snobbery, just my opinion. The larger is (to me) an ordinary, run of the mill
Larger and the pacific ale is just a mild APA. I'm finding my taste in beer and wine getting bigger and bigger, these just don't do it for me any more.
Enough of beer. Time for spirits. :P
Mountains were fun. :) need bigger brakes and coil overs.
This is true, I need suspension and brakes, I swear pinky has neither... They are so stock I think they have disintegrated lol
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
    • Have you done 10x restarts since it came on?
