Mugabetown - Whoretownin' At It's Worst.
waz so tempted to google that but then I realise something........................
better not :P
Hahahahahaahahahahaa Don't you love those oh yeah I will google that ooooooot not... Either one...
yes. my six sense helped me out there ;)
Mine alludes me more often than not... Until I google and go ahh yeah not what I was after... I was going to oktoberfest and trying to find part of my costume I ended up on a porn site... I was like ahhh well those are the style of thigh high socks I want but ummm not attached to her doing that...
This is what my day has been so far. 400m3 of concrete 20 tonne of steel prefab sections going up. And handing over a new section of mall for fit out. All go today, f**k Mondays.
  • Like 1
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
