Mugabetown - Whoretownin' At It's Worst.
They must just love me :verymad: Or they figure if they pull me over on the way to or from work I am usually wearing a short skirt, gives them some entertainment for the day...
you should charge them a fee every time they RBT ya
Back to seedy old men already???
Story of my life...
I wish I could, once it happens a couple more times in a short timeframe I will do what my boss told me to do and go in and complain about harassment for being pulled over too many times in a short timeframe, targetting because of the car I drive. Apparently someone she knew found that out after they were pulling him over all the time for "random" breath tests
I have that Pink Fluffy Unicorns Dancing on Rainbows song stuck in my head on loop. Bloody subliminal my little ponies :)
Hahahaha I think I need to watch that now... And the hungry one :yes:
Can you please do that to all of them, including ones with flashing lights lol
Hahaha I wish, there is a really painful set on my way home from work everyday, 2 maybe 3 cars get through then it is red again and all the other lights at the intersection are green for a minute each argh.
They should replace traffic lights altogether with big sweeping on ramps and off ramps. I get stuck and silently will them red go green, red go green, red go green or me go red :)
I wish this worked for all intersections however the delays whilst upgrades were occuring would be balls...
This is a more risky rehash of a US show that had married couples at it for 7 days to improve there relationships. It was really awkward to watch the before and after interviews. No intercourse shown.
All I could say is... For the guys sake they'd want to be filming closer to the equator :)
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
