Mugabetown - Whoretownin' At It's Worst.
This is true, it's like a trademark, Zane can't find me just sits down and looks for the legs, that's how I lured him in...
Wiley
From now on you are known to me a Melly the Wiley, as i typed this it occured to me that could be combined to create Miley. Miley it is.
No way, that's my trademark too.
He wears short shorts
Wiley
lol..................for so many wrong reasons its funny
Wiley
Saying I look like a retarded cow?
Miley-Cyrus-and-Taylor-Swift--MTV-VMA-Aw
I misspelled Wily, oops
In that case, yes, I am possibly...
my bad.............eastsiders or outsiders, foreigners, Martians, Nick, space Cadettes, space invaders
That's better :)
ORLY good work! Brave brave man...
Posting. Posting. Posting.
Also fapping at that motor.
Back to posting.
Back to fapping.
^this is a man that knows how to fill space on a post to add a page...
Other option is this....
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
    • Have you done 10x restarts since it came on?
