Mugabetown - Whoretownin' At It's Worst.
Sorry, up the road towards city. Units next to the servo (used to be BP?) and Dominos (possibly still there???)
Right near where that mechanic crashed the customers porsche and died couple of years back.
Ahh i see, its a 7/11 servo now and dominos is still there, that's pretty close to my place.
The Breeze is good down there, we go to the park to do our work outs by the river, great spot for it.
Everyone thought it would never flood again I think!
Well if they didn't use wivenhoe as water storage we wouldn't have had the problem in the first place :/
Well it is designed with both storage (46% of capacity) and flood mitigation in mind (54%) and is only designed to reduce peak height by a meter, it achieved this in 2011. It was peoples expectations that failed rather than the dam! Most of the water came out of the Lockyer anyway which joins the Brisbane River below the dam, it was all just a series or really unfortunate events.
Yeah I guess. Then started the blame game :/
Yeah, the flood commission was a total joke with the finger pointing, some of my measurments got submitted as evidence to that, had to go and sit there for a day, terrible waste of everyone's time!
Such a fun job :P Do you often get questioned regarding the validity of the data you provide?
Always
Yeah although it's not the best image to have the exec arguing publicly like that :P
Just start a little earlier ;) by the time we get there only the crying is left
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
