Mugabetown - Whoretownin' At It's Worst.
Haha. There is a good mix in here I think. Nick and Cowdy are under 22 & we have a few 30+ers
You, I don't know about you, but I'm less than 22 everything will be all right if I keep listening to Crüe. And you don't know about me but I be you want to everything will be alright if we kept dance listen-inch to Crüe whoa oh oh oh oh
Also Zeke is 21 same as me, zac isn't even 20 yet
Where are we going :)
To the moon and back.... If you'll be, if you'll be my baby
Sup slaarts chillaxing at work, legs are killing me as I went for a jog yesterday (I know right, cardio? What is this witchcraft)
wow I'm 33.
In unrelated news, I got hit in the chest by a bird at 100-110 on the way to work this morning. Hope it was a magpie. f**ker.
Your chest f**ked up a bird, #chestbrah
Stop chatting up my woman! Hahah nah all good
Take me for a run?
Fine she be blocked!
I went for a run/jog yesterday your welcome to join me.... I'm the anti cardio spokesman so I don't really know what I'm doing lol
yeah you lost me with that one
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
