Mugabetown - Whoretownin' At It's Worst.
Haha. There is a good mix in here I think. Nick and Cowdy are under 22 & we have a few 30+ers
You, I don't know about you, but I'm less than 22 everything will be all right if I keep listening to Crüe. And you don't know about me but I be you want to everything will be alright if we kept dance listen-inch to Crüe whoa oh oh oh oh
Also Zeke is 21 same as me, zac isn't even 20 yet
Where are we going :)
To the moon and back.... If you'll be, if you'll be my baby
Sup slaarts chillaxing at work, legs are killing me as I went for a jog yesterday (I know right, cardio? What is this witchcraft)
wow I'm 33.
In unrelated news, I got hit in the chest by a bird at 100-110 on the way to work this morning. Hope it was a magpie. f**ker.
Your chest f**ked up a bird, #chestbrah
Stop chatting up my woman! Hahah nah all good
Take me for a run?
Fine she be blocked!
I went for a run/jog yesterday your welcome to join me.... I'm the anti cardio spokesman so I don't really know what I'm doing lol
yeah you lost me with that one
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
