Mugabetown - Whoretownin' At It's Worst.
Morning all
I imagine he starts work obscenely early tomorrow.
Bingo, up at 4:45
Engineer me thinks
Yep
bet ya he's on da big bucks. And he's smart enough to invest it rather than spend it.
I'm saving the lions share, but that's not to say i'm living like a monk either.
Investing the savings, on the other hand, needs more work
Soooo much progress for the charity cruise last night. All will be released on Wednesday. My rad hurts from progressing so far. :(
Good to hear!
Now just make sure you run it during my RnR...
I submitted QLD registration form, but haven't received a response email with pymt details.
Is this usual, or should I complete another?
Just checked google drive and your application is there. Were currently going through a change in the membership secretary role and Martin (the old guy) has been pretty flat out.
Someone will contact you shortly.
Morning all
Bingo, up at 4:45
Yep
Good to hear!
Morning Pete! 8 December for charity cruise mate. Got a pretty great route organised.
Morning all
Bingo, up at 4:45
Yep
Good to hear!
Hi Pete, what type of engineering work?
Thanks for following this up :)
