Mugabetown - Whoretownin' At It's Worst.
Kids these days, cant handle thier booze! Just start earlier pass out at 9 still have 8 hours or more sleep.
I went hard from like 11-4 then slept til 6 this morning haha
I was 22-24. Was heaps of fun.
I did similar 19-21 but usually I would get home have a shower and straight to work, and that was without alcohol because I was always driving just didn't sleep and lived off redbull and mars bars...
When I was 22 I would work for 7.25 hours somewhere between the hours and 6 and 6 which I chose then go and do all the things you described the working lots and the no sleep is the part that sounded pretty shit to me!
Engine out.
Morning! That baby better hurry up. You don't want it arriving the day you get your car back!
have been thinking that everything will come at once........................thats usually how it goes.
So found out today, that seedy Sunday sesh' are not a good idea
well you get learn......................I have no doubt in my mind you will somehow learn this the hard way :P
Think there's something wrong with my radiator. We filled the radiator and reservoir up on Saturday, checked it Sunday arvo and the reservoir was empty. Curious..
was the engine getting hotter than usual?
Could have been an air pocket
most likely this ^
Eh, temp gauge was a little high yesterday and when i pulled up I saw it was leaking. It's all good, to the falcoon
fix if fix fix it fix it fix fix fix it fix it rb it fix fix fix it fix it fix it
you know u want too :nyaanyaa:
Its hard separating the good info from the bullshit, and then figuring out how it will effect stock prices but I guess I'm a step ahead of any other industry
Day trading is pretty hard, if you were to keep shares longer its a bit easier to win but the gains are less (mostly) so you would need more capital
Nah, buy in whole hog on the Skyline day/night market - guaranteed never to get all your money back... But the thrill of the buy and long term investment is worthwhile :) [disclaimer - don't take my fin advice] lol
lol @ disclaimer - so lawyer mentality
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
