Mugabetown - Whoretownin' At It's Worst.
Which model got the nuremburg record again? :P
The 32 originally :P Nissan would hardly make a new model if it wasn't going to out preform the pervious model hence why the 34 was faster then the 33 and the 33 faster then the 32. However if I am not mistaken the 32 has the fastest 1/4 mile out of the skyline GTR's
That's because I haven't run yet lol
QGC gas fields south of Chinchilla.
edit: to be fair, optus itself does work in chinchilla itself, i think, but where i actually spend 50% of the time it doesn't.
edit edit: and I wouldn't hold out much hope of it working up north of wandoan where i'll be based out of as of saturday
Wow, slow night on thread
And what happened to Melly - F111. Flew in for a Riverfire Optus dump, burn and then retired from thread lol
it's been a very slow day for me haha lots of sleep and tablets just to try and get over this cold
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
