Mugabetown - Whoretownin' At It's Worst.
I kinda hated it compared the the German Club one, having to buy Beer tickets in particular really ground my gears
We bought a whole heap when we first got there so we didn't have to go back and buy more :)
So what you're saying is that no one person has met all three criteria lol
Unfortunately I have. He also crash tackled me into a bin at my birthday party last year
Yeah thats the one. Noticed he dropped the price the other day and I know how much he spent on it.
That or IanB's blue one on the radar at the moment.
Decisions...
I would go Desteros, Was built at the same time as mine using the exact same internals, its solid as!
Fair enough!
I have seen you in a V neck Tshirt which is even gayer
Nein
I wear v necks all the time... I'm just curious as to when this was because I thought we'd only met once and on that occasion I was in a black button up shirt
I saw you before I met you...through your bathroom window
Good times good times lol
It's ok your big enough and ugly enough to handle it.... Imagine if I did it to poor widdle 180 nick he'd die :P
(Or kungfu my drunken ass)
:) tell more about how the tackle came about lol
Was a love tackle, Chris picked me up off the ground and then I went to lift him up but was way to pissed (had literally drank a bottle of scotch) and it kinda tuned into a suplex into the bin and cans and Chris landing on top of me lol
We had been drinking since 10:30 am and was around midnight when this happened. He tried to be a mini hulk and bear hug me and lift me up ( I am 6ft 4 roughly and 100+ kgs) and he failed miserably and ended up tackling me into the bin. This all happened a month after I had surgery on both of my feet as well
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
