Mugabetown - Whoretownin' At It's Worst.
I kinda hated it compared the the German Club one, having to buy Beer tickets in particular really ground my gears
We bought a whole heap when we first got there so we didn't have to go back and buy more :)
So what you're saying is that no one person has met all three criteria lol
Unfortunately I have. He also crash tackled me into a bin at my birthday party last year
Yeah thats the one. Noticed he dropped the price the other day and I know how much he spent on it.
That or IanB's blue one on the radar at the moment.
Decisions...
I would go Desteros, Was built at the same time as mine using the exact same internals, its solid as!
Fair enough!
I have seen you in a V neck Tshirt which is even gayer
Nein
I wear v necks all the time... I'm just curious as to when this was because I thought we'd only met once and on that occasion I was in a black button up shirt
I saw you before I met you...through your bathroom window
Good times good times lol
It's ok your big enough and ugly enough to handle it.... Imagine if I did it to poor widdle 180 nick he'd die :P
(Or kungfu my drunken ass)
:) tell more about how the tackle came about lol
Was a love tackle, Chris picked me up off the ground and then I went to lift him up but was way to pissed (had literally drank a bottle of scotch) and it kinda tuned into a suplex into the bin and cans and Chris landing on top of me lol
We had been drinking since 10:30 am and was around midnight when this happened. He tried to be a mini hulk and bear hug me and lift me up ( I am 6ft 4 roughly and 100+ kgs) and he failed miserably and ended up tackling me into the bin. This all happened a month after I had surgery on both of my feet as well
