Mugabetown - Whoretownin' At It's Worst.
Was a love tackle, Chris picked me up off the ground and then I went to lift him up but was way to pissed (had literally drank a bottle of scotch) and it kinda tuned into a suplex into the bin and cans and Chris landing on top of me lol
Lol just lol
We had been drinking since 10:30 am and was around midnight when this happened. He tried to be a mini hulk and bear hug me and lift me up ( I am 6ft 4 roughly and 100+ kgs) and he failed miserably and ended up tackling me into the bin. This all happened a month after I had surgery on both of my feet as well
That is too funny lol (with exception of feet)
single cam 30? Pass
How much is the other one going for now Col and Pete? Beause the price as of May was optimistic to say the least!
Dunno about the white one,I've always been after a blue one though which is why it caught my eye, just 2 days after I left Brisbane. Benno seems to know something about it so now om intrigued though
Ahh i see, the blue one has been around a good while, Spilmer owned it before Ian.
Link to Ians sale?
Edited by Bunta
Not bad at all, all it needs is a rebuild and probably a different computer.
But do contact Benno, I think there is some accident history there somewhere?!
Edited by Bunta
shh, I was hoping I'd be able to go take a look at that one once on off swing..
Shieet son. Better hurry up then :-P
Link me to the white one somebody!
On gumtree not listed on carsales. On phone so cbf with links.
Blue 17k. Sounds like a steal. I know Spilmer was very particular dont know how its been treated since.
White one is at 25k. Will need to look at it in the flesh to make a decision but I know he spent more than that on it with the motor and other go fast bits.
+ it has most of the gear ready to swap out the 35r and put in a new precision or efr turbo
yeah, go buy the white one! :P
In your opinion (or anyone elses), is a motor at that sort of age making that sort of power a ticking timebomb, or just something you'd want to do one day soonish? or am I misreading the ad and the engine itself is actually cactus already?
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
