Mugabetown - Whoretownin' At It's Worst.
This explains the eyeliner removal tip lol
Well yer, I've got a big framed picture on my wall in the band room with full blown hair make up 80s rock god mode from a gig we played. People walk in and are like "wtf were u thinking" and I usually think "who cares it was tons of fun and I bet you wouldn't have the balls to wear it in front of 50~1000 people so shudup " lol
i still want to know the secrets of these natro stages.
Step 2 is being completed either tomorrow/Saturday/Sunday....
Step 3 within the next monthish, step three is a fair bit of coin... Step 4 is the one that really hurts though :/
and then they think, "no, i just wouldnt want to wear it in the first place, let alone infront of 1000 people"
Lies, if I could get away with it I'd rock eyeliner everyday ... But alas, I'd probley be fired and not allowed into anywhere lol
Can i start calling you gay boy nick? Haha
And morning all
Depends how you like your face arranged? :)
Anyhow, cold morning is cold and apparently of you don't check your water levels on your dirty falcoon they get hot when your driving to work lol
yes chants we can look after the ant-eater while ants is busy with child :) we wont hurt it :whistling:
Gawd no. I can just hear you all whispering about which mointain to take it over first.
We are a very large sometimes deranged family here at SAU, I know that if any of our members were in need we'd have 5 plus people offering to help
ok then 2 handy shandys in my reachbank
tre if you come up here and drink with the qld whores you are in the currency
Cos we all know that SAU QLD can drink...a lot.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
