Mugabetown - Whoretownin' At It's Worst.
This explains the eyeliner removal tip lol
Well yer, I've got a big framed picture on my wall in the band room with full blown hair make up 80s rock god mode from a gig we played. People walk in and are like "wtf were u thinking" and I usually think "who cares it was tons of fun and I bet you wouldn't have the balls to wear it in front of 50~1000 people so shudup " lol
i still want to know the secrets of these natro stages.
Step 2 is being completed either tomorrow/Saturday/Sunday....
Step 3 within the next monthish, step three is a fair bit of coin... Step 4 is the one that really hurts though :/
and then they think, "no, i just wouldnt want to wear it in the first place, let alone infront of 1000 people"
Lies, if I could get away with it I'd rock eyeliner everyday ... But alas, I'd probley be fired and not allowed into anywhere lol
Can i start calling you gay boy nick? Haha
And morning all
Depends how you like your face arranged? :)
Anyhow, cold morning is cold and apparently of you don't check your water levels on your dirty falcoon they get hot when your driving to work lol
yes chants we can look after the ant-eater while ants is busy with child :) we wont hurt it :whistling:
Gawd no. I can just hear you all whispering about which mointain to take it over first.
We are a very large sometimes deranged family here at SAU, I know that if any of our members were in need we'd have 5 plus people offering to help
ok then 2 handy shandys in my reachbank
tre if you come up here and drink with the qld whores you are in the currency
Cos we all know that SAU QLD can drink...a lot.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
