Mugabetown - Whoretownin' At It's Worst.
Off to brissy to pick up Stage 2 :ph34r:
Dont be "That Guy" Nick!!! Spill he beans
We could do tomorrow arvo? Around 3?
Cant sorry, booked up with house hold chores in the arvo? Missus has me on yard duty
Im beginning to get that feeling... Feel free to PM me your idea/stage 2 plans
You know considering im so open and sharing about mine!
Bahahaha, it's all good mate it'll be going up in my build thread but only piece by piece
I see him trawling this thread as we speak :yes:
Interested to see what results we all get. There is another guy on here that just got his results back on a very very similar setup to what mine is. It made 480rwkw's on 27psi. 6466 with .84
huge numbers that is...........huge!!!
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
